rumcayman,
The powerplate is a proven way to equalize the airflow into all cylinders. Has been used by many on this board. They are made by RJC and alot went into testing with these by RJC to prove that they did what they said.
Then you will just need to:
1. get rid of the 7th injector setup.
2. put the RJC power plate in.
3. Upgrade your injectors to 60lb motrons (bigger than 60 injectors can't normally be used on unmodified ECU's because their low impedance is too low and can blow up the injector driver IC's in the ECU).
4. Order a chip from turbotweak/gbody/fullspeed throttle giving them your setup info.
If you want to upgrade your setup from stock for more HP then you can add various things to your combo.. First hits on the list of things to increase your HP is as follows:
1. Replace and put in a bigger downpipe.
2. Replace your injectors as described above.
3. Replace your turbo with something a litle bigger.
3. Get and install an Alky kit.
Either way here is link to the turbotweak site to see what info you need to gather from your setup:
TurboTweak Home
D
Don
