7th Injector?
Shane
Moderator
I'm familiar with what the 7th Injector does and what it's purpose is but I have noticed that not many people use them.
Is this a throwback to the early TR days? Are there any performance gains?
Yep, throwback. You can make much more refined power with a set of larger injectors and a chip to match, since the fuel is distributed equally among all cylinders. Adding that 7th injector, runs fuel through an intake designed for only air, and is subject to starving / over fueling certain cylinders based on the airflow of the intake.
Right up there with people that had to use volt boosters to compensate for the fuel pumps inadequacies. Nowadays, hotwire kits and high-flow pumps fixed that. Some still like the volt boosters, but its more related to computer/injector/spark concerns instead of fuel pump issues.....
