81LimitedT
- Jun 5, 2001
Hello all!
I have a situation with my Hybrid build. Currently we've gotten the rebuilt motor to kick over after 30+ years dormant. Original carb NOT rebuilt. New mechanical fuel pump & pressure regulator's at approx 5.5 psi. The carb starts to overflow shortly after it started. Not using the pusher electric fuel pump in the tank (10 psi if it were wired in).
The only thing i didn't do was use a fuel filter in the carb inlet as it already has a large inline filter in the frame. (I did buy a new wix filter for this stock location but haven't installed it yet.) Could this be an issue, or do I need to get into the carb for a more common issue with these setups? (stuck float, needle, etc?) Any suggestions are greatly appreciated.
-Mike
-Mike
