82regal w/ 87 drivetrain
ssleeper94
will it run?
I have no time for the car anymore, baby due in a month,
Its an 82 w/ 87 drivetrain body is super straight custom paint job done by pervious owner little rust on the floor plan was cut on and fixed. tons of extra parts, needs little to finish. here's whats done
engine
stock 3.8
rizzuti ported heads
custom ground cam
ported intake
ported doghouse
huge front mount ic. 3'' pipes
55# injectors
3'' dp
3'' mandral bent exahust
atr wastegate
accel gen vi dfi
te=64 turbo w/ no play
f-bod radiator
t400 trans w/ brake
9'' converter 4000 stall
stock 8.5" rearend
umi upper and lowers w/ comp engineering shocks
boost/oil/water/fuel/voltage/tach gauges
fuel cell -8 supply
driveshaft loop
needs, driveshaft, tuning, brakes prbly need to be bled, body mounts, fuel pump/filter and wire up the gauges and switches car started and drove when it had fuel pump and driveshaft ended up selling them to a friend.
plus a ton of extra parts, spare clean doors, interior parts, and whatever else i have. asking 7000obo
junk.jpg - Image - Photobucket - Video and Image Hosting only pici have on this computer
will send pics toamrrow, bad storms right now, it will run w/ fuel pump, sold it to a friend interior in decent shape
