Basically, just tell them you want a 1227148 ecm out of an 86/7 fwd car with the 3.8L motor in it...You can buy the MAT harness from Casper's Electronics in Mundelein, IL for like $25...The MAT sensor itself could probably also come from the same car you get the ecm from...The ecm really doesn't use the MAT for a whole lot of correction factors in the code...Actually, when using TurboLink w/boost sensing harness, you unplug the MAT sensor and plug in the boost sensing stuff and the car will run fine w/o the MAT sensor...If you don't have the MAT sensor plugged in, it will just set a malfunction code in the ecm, but the car really won't run that much different...
Go here for info on the MAT adapter harness from Casper's...
http://www.casperselectronics.com/cgi-local/store/commerce.cgi?product=8485
It is all the way at the bottom of the page...
Casper's also has the fan relay kit for the 84/5s which is a piece of cake to install as well, but needs the 86/7 ecm to control it...You don't even need to run wires through the firewall for the fan upgrade kit, the kit uses existing wiring that isn't used to trigger the fan...It is listed on the same page...$79 but is pretty much a plug and play...very easy to install...
The key to swapping to the 86/7 ecm is that when you do go with the 86/7 MAF, you will be able to use all the information that is posted about the chip code to be able to program your own chips...There really isn't that much(if any) info on the 84/5 chip code out there...All the TurboBuick specific chip burning software out there is geared toward the 86/7 code and doesn't support the 84/5s...You may even be able to get by with playing around with different parameters and get it to work with the hybrid 86/7 ecm using the 84/5 MAF...But it all boils down to switching to the 86/7 ecm...
I've done both of these and it is the best bang for the buck that I have spent on a "hotair" car...
Hope this helps you some...
