Aah, ok you're referring to the CCCI module, not the ESC. The outputs to the sensors are internal, so if you don't have around 12 volts at the gray/red wires, the module is defective. You could jumper the 12 volts (pink/black) to the gray/red wires - 8485 only - but that's a band aid. You need to find out why the sensors lost power, generally an internal failure due to a short.
