84-85 manaflds on a 83
If you are talking about the headers and crossover, then yes. I have a rewelded 84 on the passenger side of mine.
they are the same, except for maybe the heat shield on the driver's side.
Yes, but you need the right crossover to go along with them. The 81/82 were narrower.
I don't like the tube header. Everything I read about turbo system preferred cast iron. Their only drawback is weight. I'll take a few pounds over cracking. Both my manifolds cracked with only about 50,000 miles.
I use 1980 cast manifolds with the 83 crossover and up-pipe. Take a look here...
BEFORE BLACK - Turbo V6 Exhaust Manifolds
So that means the aftermarket headers for the 84-85 should also work for the 83. Right?
