XcessiveBoost
SpeedFreak
- Mar 7, 2006
i know for sy's and ty's a turbo sunfire ecm will work in the trucks if you change the chip... what will swap for my car?
BRAD_PADGETT said:There is no need to upgrade the 84/85 coil pack until it fails. Casper Electronics (Poston is a reseller) makes an adapter which allow you to plug in the 86/87 coil pack into the 84/85 wiring harness. Cost for the adapter is around $60. This is alot cheaper than finding an 84/85 coil pack and they do look fine. Brad
Hey Slow,SLOW_85 said:......... Accel sells the 87 coil with an adapter plate for the 85 ignition coil. The 87 coil will work on the 85 ignition module..
XcessiveBoost said:i know for sy's and ty's a turbo sunfire ecm will work in the trucks if you change the chip... what will swap for my car?
