84 hot air install
mike84
looking for a good kit, any ideas need some pics i want a clean install thanks
First thing you need to do is convert to 87 electronics/chip/maf/etc.... Then have a scantool like a scanmaster.. then tweak on it until its running correctly.. finally after all this.. consider the alky.
I dont have any 84 pixs. I've havent sold very many.. like 10-12 hot air kits. And they all are different cuase some have IC, some dont.. It does work.. without an IC.. bout 20 PSI on pump gas+alky.
HTH
Alky/water injection was meant to be on a hotair car. Almost came from the factory that way, just check out that power injection light on your dash that doesnt get used ;)
mike84, you wont be dissapointed adding it to your car. As far as Razor's kit, I felt it was good enough for me to scrap my home made alky kit that worked great for years. He has covered all the bases and always improving + he is not just a vendor but actually uses the product with much success. VERY clean install. I will try to get some pics when I can but for the most part looks the same as the 86/87 install with the exception of the line for nozzle routing along the passenger side to the turbo-intake adaptor at back of engine. Makes for a bit more stealth than later years if thats what your looking for. Only other diff is the need for a solenoid in line to keep alky from being siphoned unwantingly when system not in use because of draw-thru throttle body setup (TB before turbo).
IMO any forced induction vehicle greatly benefits from alky/water injection and double if you have no intercooler.
