Hello everyone. I recently just picked up my first T-type. It's kind of a odd situation, but I rebuilt the bottom end before I bought it from my boss. But anyway back to my post. I recently got it up and running and back to my house. It runs good not as strong as I think it should be but that's why I'm posting.
Here's what's going on. The car seems to idle decent little hiccup every so often. It seems to take a while to build boost and get up and go. I have no codes present and the snap on scan tool I have is giving all the readings on the IAC TPS Coolant block intergrade so on. Everything seems to been working and sending its information back to me. Tps is set at .43, iac is 114 area, A/f learned. I have hot tanked and cleaned the injectors they all sound healthy and clicking clearly. But when I blip the throttle it has this little hesitation then goes. I have checked the wastegate line for the brass restrictor and it is in there also all the vac lines I have ran correctly like in the diagram on the fan shroud. I have read on the forum that the stock 84 ecm is kinda lame and I can upgrade to 86 87 computer with a addition of a AIT. Also is there a chip for a 84 ecm
I have a slight exhaust leak on the cross over but its nothing major just a little puff puff. But if you guys can help me out with some ideas or even some things I can do to help my new toy out. PLease let me know.
