I was on the highway and the car started too sputter when I would give it gas so I pulled over the car was still running check temp everthing was good killed it and it started with no problem when I tried to take off everthing was still fine until I floored it it started to sputter pulled over again my cousin said it might be the cat so I beat it and you could hear somthing loose so this morning I was going to take it too the muffler shop to get the cat cut off and it wouldnt start so I pulled it over there got it cut off still wouldn't start put new plugs and after a lot of cranking it finally started now It sputters if I try to floor it in park I can give it a lot of gas but in gear in sputters and really no power now???????
