84 T-Type AIR DAM
cesarp
I'm missing my front air dam, the black trim that goes under the front bumper. They have discontinued the 84 - 85 year one. GM still carries the 86 - 87 but is a 2 piece. Does anyone know if this will bolt right up or will I need additional modifications for the 2 piece to fit. Thanks.
My T-type has a 2 piece front airdam, not sure if its original though. Actually still has a readable sticker on the inside of it!
It is not the original according to GM. The 84 - 85 only had a 1 piece. But I might still put the 2 piece on from an 86 - 87.
I have an '84 T-type and bought both - mine had the short air dam that all regular Regals got. You may use existing body/frame bolts for either but I secured the
inner edge of the two-piece version (which normally leads to intercooler scoop) with zip ties because they were floating in space. I mounted a junk yard fresh air scoop down there but later removed it because I was picking up too much road debris. The '84 GN air dam is there now.
