85 BGN HOT AIR Engine and Transmission 88k
AntMan
Up for sale, one 85 BGN Hot Air Engine w/88k miles, and rebuilt JASPER Trans. w/10k miles. Wire Harness, Computer and all accessories included (Alternator, A/C Compressor, PS PUMP etc.)
Engine needs timing cover, gears chain and pump gears, and rod bearings replaced otherwise engine runs strong with no leaks or burning of oil. Many gaskets grommets and hoses are brand new.
Transmission, Jasper Rebuild approx. 10k, comes w/steel lines filler tube and kick down cable, and orginal torque converter. Trans is locked up not sure what happened worked flawlessly.
Asking $1200 for the total package (Engine Stand, Trans. stand NOT included)
call w/any questions 540-623-7402 or email afrances44@yahoo.com
Lowered price to $1,000 also will throw in a leak free radiator out of the same car 85 BGN
Video of Engine running prior to being pulled out last year, does not burn oil, no leaks, if you listen at around the two minute mark you'll hear the rod bearing noise.
