85 t-type roller
cooled85T
Empty Pockets
Car has a bunch of new parts on it, just needs motor and trans. Has all turbo wiring and ecm. 2 1/2 hooker exhaust with test pipe. 3" BGC downpipe included. VDO guages (boost, trans temp., oil press, water temp). I took all the AC parts out but still have them if you want them. Polygraphite perf. front suspension parts, new poly body bushings, cargo springs in rear, bilstein shocks, aluminum drums, high press wheel cyls., new rear pads, new front rotors, pads, calipers(been sitting for awhile so they dont look new), vacuum brake setup, 8.5" 10 bolt with 3.42s, posi unit works good. Comes with centerline wheels. Bosy is in fairly good shape. Doors have small rust spots starting int he corners but can be easily fixed. Roofrail has small rust spots starting to bubble. Floorpans are rusted through, its had some patches put over the holes. Pics are older from when it was all together. I have the fender, hood, and bumpers off from the ac delete and body bushing install. It needs door hinges on the drivers side, pass. side could get away with just pins and bushings. Interior is the nicest part. Has custom bucket seats, I havent seen any like them before. Could use carpet, drivers seat has a small tear starting, and steering wheel needs to be dyed tan. Other than that interior is in nice shape. All trim is in pretty good shape, bumper fillers dont have any cracks but the paint is peeling off. More pics available. Would make a nice easy project for someone that has a motor and trans to drop in. Asking $3500 obo. Does have clear MD title. Willing to negotiate. Located in central MD. This car needs to go!
more pics
more pics
more pics
same wheels as the rears come on the front just dont have them bolted on. Has a nice matching turbo hood and bumpers. Have to be serious now, asking $3000 obo.
Pics on the trailer are how it sits at this time. Everthing is there to put he car together except motor and trans. Have bumpers, grille, rad., hoses, overflow tanks, heat/ac box comes with it if you want to put that back. I will post pics of the rust spots a little later. $2000 cash, If I cant get someone who says they want it by this sunday its getting parted.
