Every nut, bolt, bracket from the heads up are different. You will need the passenger side header, accessory brackets, alternator, powersteering pump, AC or AC delete kit, belt, hoses, pullies, main wiring harness+ injector harness, downpipe, turbo bracket, oil return, oil feed, coilpack bracket, TB, intake, throttle cable, MAF pipe, and a whole lot more I'm forgetting. In other words, it's much easier to find a complete motor. My dad did the conversion piece by piece and he laid out an engine break down for both years and started ordering parts and getting them where ever he could. It took about a year to get them all. I really don't see the need with the TM kits available. I should start buying all the the intakes from the converted cars. I need some to experiment with.
