86 87 109 Motor Rebuilt 0 Miles + Rebuilt Brf Trans
GNX 120
Forsale is one 87 109 motor out of 87 gn rebuilt with no miles, Motor is 30 over with stockcrank and rods, new trw forged pistons,new comp cam slightly larger than stock with new lifters and pushrods. New timing chain and cam button,a new arp main and rod bolts blueprinted lower end? Heads are also redone, with new valves and springs with slight port work. Motor comes as shown less valve covers. Timing chain cover,oil pan,waterpump, and flywheel all come with motor. This motor was rebuilt by Larry's machine in CT and installed in car and only run once never driven. $3000 OBO Trans is also rebuilt with about 1000k miles stock rebuild with mild shift kit and new converter. Good driver trans $850 Local pickup or you setup shipping. ANY QUESTIONS CALL #774 696 3585 THANX KERRY
Pic's
Motor And Trans Pic's!!
Tires!
Steve here is the pic's of the tire ! THANX KERRY
Engine
I will give you a call tonight sometime. I'll check and see if G&L transport has a terminal in your area.
