driveshaft man
- Oct 5, 2007
I spent the weekend helping remove the spent pieces from my buddys GN. #5 has large gaping holes in the cylinder walls, broken thru to water jacket at top , and no piston,just a rod and pin in the hole. 2 questions ; why sudden failure , no noise or indication prior. Failed at medium throttle,spooled up at maybe 3500rpm,2 nd gear and poof...done! and 2nd question, will blocks from other 3.8 s interchange or were turbo blocks better/stronger and worth paying the big money to find ?
thanks Harold
thanks Harold
