highboostgn
- May 24, 2011
Posting for a friend.
First off this car is immaculate. It's fast yet not abused or ran at the strip. And is show quality. He has a whole wall of awards and placks to show for it. Located in Bay St Louis , Mississippi. It's a steal a 24k.
1986 Buick G/N. One of 5,512 made.
Owned since 1992 in Orlando ,fla
FAST XFI SYSTEM
FAST XFI EDash screen.
Fiberglass bumper mounted on alunim bracket.
71QHP Precision Turbo
87 Grille
RJC 325 Mega FMIC
RJC Pullies
Aluminum Radiator
Aluminum Radiator cover.
Turbo Saver
Razor alcohol system. Duel Nozzle Setup
Champion Intake
70mm Throttle Body
RJC 4" Inlet Pipe
72lb injectors.
New hotwire injector harness from Caspers with relay.
Headers new from Club Hedman
Champion Fuel Rails.
All aero motive fuel cell in trunk 1000 HP fuel pump
10 from pump, 8 to fuel rails, 6 return
Heads from Hughes ported polished largest valves that will hold.
T&D Roller Rockers 1.65
109 block bored .020 over 4 bolt main caps. All compents from comp
Roller stroker motor balanced, blue printed ect.
Solid mounts.
Lonnie Deeres Stage 2 200R4
Edge 3000 stall converter.
Bm trans cooler.
Complete H/R rear set up.
New rear end 30 spline mosser axles.
Complete new posi unit /girdle. .
Rear bumper fiber
glass aluni um braces.
Gnx bar across back of seat area.
Line lock.
New tires front and rear. Conv pros..
And 500 Worth of autometer gauges.
Leather GN seats.
Off the frame. All new bushings neaprem minni tubed correct. Weight reduction air cond delete stuff and more. Comes with a few 200r4s. A few blocks and tons of other parts
Trades -05 Newer corvettes, auto.
Contact me text 228-424-5607.
FAST XFI SYSTEM
87 Grille
RJC 325 Mega FMIC
RJC Pullies
Aluminum Radiator
Turbo Saver
Champion Intake
70mm Throttle Body
RJC 4" Inlet Pipe
72lb injectors.
Solid mounts.
Bm trans cooler.
Rear bumper fiber
Line lock.
Leather GN seats.
