86 olds cutlass,black buckets ,tilt ,cruise control,floor shift with console burgandy int mint.non smoker.boost gage air fuel gage,factory gage package.outside black excellent condition paint faded never hit.lightweight front and rear factory bumpers.gn rear.new gm brakes front and rear.new fuel tank with new sender and red armstrong pump.aod trans with 10.5 inch concerter,sfi bellhousing and 2.84 planet.030 short block with forged pistons ,206 206 roller cam,ported and cramic coated heads with ferrea valves locks retainers new springs,poston ceramic coated headers,th down pipe,55 pounders high impedence(no computer mods necesary)translator plus ,lt1 maf,precision front mount,turbo tweak chip,new gm module ,ecm and coil pack,new oil pump timing cover and pump,engine 40 psi hot idle 85 psi wot.new flywheel,ta rocker shafts,gn fuel lines installed with all factory clamps in place,eibach 1 inch lowering springs,hooker dual exhaust,wiring harness better than new ,inner fender wells from gn both sides ,cold ac,new ps lines,.this job was done like the factory would have done it,aldl functioning,4 new 16 inch tires with gnx style rims .no cut wires immaculate job.$12,000 firm.if interested email me.car has gone 11.50s so far @118mph with out proper tuning.now running perfect will track test in a few weeks again.
