87ponykiller
- May 7, 2008
Complete rebuilt motor with TRW replacement forged pistons, stage I cam, Fererra valves, T&D shaft rockers, Champion valve covers, new fly-wheel.
Mods include: gt6157e precision turbo, Terry Houston 3" S.S down-pipe, Flow-Master dual exhaust system (SOUNDS AWSOME), turbo tweak chip, motron 60 injectors, adjustable waste gate & fuel regulator, Walbro fuel pump, 3" chrome inlet pipe with cold air kit/K&N, H.D cooler hoses, H.D aluminum radiator, smc alcohal injection kit.
Every sensor replaced with new GM after motor was installed. New Delco battery/cables.
Precision 9/11 L/U converter, shift-kit, Art Carr deep trans pan,
Factory 8.5" posi with 3.42 gears,
New front end suspension (Billstein shocks/springs tierods etc).
Factory T-Tops, Digital dash (new upgraded 195 mph unit from Caspers Electronics)
Car currently has 87 GN front/rear seats,
New carpet & floor mats, column shift, but has a GN console to go with car. Power antenna still works perfect
Rear GNX seat braces, front end upper & lower braces (CAR IS TIGHT)
Needs a heater core(currently by-passed)
Runs excellent, very reliable and fast, 11 second car you can Drive anywhere, and can easily be made a lot faster!!!!
