so i been seeing motor oil which i have come to it being the valve cover gaskets.. i should tackle that this weekend.. but after looking a little closer i noticed brake fluid has been leaking.. brake light has been coming on and off.. i did the car off 12 times brake pedal down to depressurize the system, turn key on and brake light goes off within 5-7 seconds. but i did notice that fluid will come out the top of the resivor cover. and spill out onto the frame etc.. so i thought it was slightly over filled.. took some fluid out last night and it stopped only to see it again today with less fluid in the master cylinder.. and still coming out the top? anyone know whats up? thanks.
