87 ' GN ,Florida car ,well build , cash or trades !
gczarny
fast is cool !
Hi everybody , about 80k on the body , it's got T tops ,power seat /windows /locks ,working AC/heat , it's Florida car so there is no rust ,body have original paint in good condition ,has couple of small dings on the hood in one dent on the roof where basketball landed ( thanks kids ! ) easy to pull out for dent buster .
I am a weekend racer , I should say I was since I have not raced this car for over 4 years ,back then car had forged but standard stroke /bore motor that was tuned for 93 octane gas and Alky only and ran mid/low 10's at 132-134 MPH , never been tuned for race gas so I did not know it's real potential but you should all agree that with what I got in it should run well into 9's especially with Weber stroker motor it's in it now . Car needs to be retuned because of this
motor swap , asking price is $26.000 or BO , I will consider trades plus cash ,mostly looking for convertible car or boat 25 to 30 feet but I will consider any trade .
So here it is :
Motor is almost 4.1 L . now .
Weber stroker , 3.55 stroke ,0.040 ' overbore ,girdle ,Gn 1 heads and intake ,1.65 T&D roller rockers ,70mm upper dog house and TB , 220/224 roller cam , F body radiator with dual fans , both polly motor mounts .
Turbocharger/exhaust
Dual ball bearing 76 GTQ , 3 inch all the way trough 3 muffler system for lower street noise , external gate controlled by Apexi boost controller that could be sold off and boost control given to Fast XFI for example . Precision front mount IC , Razor dual nozzle alky kit with alky pressure and fuel pressure logging into Fast XFI ,
Fuel /Spark
Fast XFI for fuel , Fast XIM for spark with coil on plug set up from Cal , 6 EGT probes logging into Fast XFI , you can not ask for better spark/fuel control and EGT feedback set up :) , double pumper in a tank ,83 lbs injectors . FP and injectors hot wired .
Trans, rear end ,brakes ,suspension
turbo 400 with manual shift and trans brake , 3200 Art Carr none LC TC , aluminum racing drive shaft with loop , 9 inch Ford -Detroit locker with dual piston disc brake conversion , front brakes over sized pistons Gbody calipers and cross drilled rotors , no front sway bar but HR anti roll/sway bar in a back ,front tires BF g-force sport 225/60/15 ,rear MT 275/60/15 ,line lock , front springs stock ,front shocks 3 way adjustable ,rear springs stock ,rear shocks QA1 adjustable , adjustable rear upper/lower control arms ,relocation brakets and reinforcment brakets for control arms .
Alston Racing 6 point roll bar set up for safety certified to 10.0 .
please email me with any questions , car located in north Sarasota area and thanks for looking .
Would you be interested in a trade plus cash? I have a nice. 2005 f150 lariet 4wd sunroof heated seats and more. Truck has 150k miles. But engine only has 63k due to local jiffy lube forgot to put oil in it at oil change. Lol. Runs perfect everything works As it should very clean and no squeaks or rattles.
Thanks for the offer but not looking for a truck at this moment , more like convertible or a boat is what I am after at this time ,thanks
