1987 Buick Grand National. Located in Ocala FL 34472 PRICE $13000
T-Tops, PW, PL with keyless alarm, AC, P/Seat, Power trunk, Power Antenna, cruise control
Body is an 8or 9 out of 10, could use a claybar and buff. Interior is also an 8 out of 10 with new carpet, headliner and visors recently recovered. Seats are nice and steering wheel recently professionally dyed black. Would take little to make it real nice.
4 dimpled GTA front rims that were powder coated last year with decent tires and new caps last year. New front slotted rotors and pads in April. Vacuum brake conversion.
Entire drivetrain rebuilt less than 3000 miles ago
Legendary 3.8L turbocharged engine rebuilt by Scottys Engines in Spring Hill FL in Dec 2013
· Diamond Pistons
· Edelbrock performer cam
· 3 angle valve job with LT1 springs
· Balanced rotating assembly
· New timing set, water pump and engine mounts installed
Trans rebuilt by Transmax of Ocala with transgo shift kit and 3000 stall July 2013
Rear rebuilt by Dan Neuman race cars of Ocala earlier this year with Detroit locker, moser axles, TA aluminum cover and 3.42 gears. Aluminum drive shaft and aluminum rear brake drums. Strongarm tubular upper and lower rear control arms.
More good stuff:
Turbo Tweek 5.7 chip, blue top 36# injectors, Alky control methanol kit, TE60 turbo, 3” stainless downpipe, Pypes exhaust, LS1 MAF and translator, Dual electric fans, RJC boost controller (currently set at 18#), RJC Power plate, Hotwire for Walbro Fuel Pump, rear seat bracing and front subframe braces. Also, rear view mirror with auto dim, compass and temp (not Buick)
Temp. boost, Oil pressure and knock gages installed in console and pillar pods. Fuel pressure gage installed on fuel rail and Scanmaster 2.1
Body is 99.9% rust free. Found a small spot in the T-top area, cleaned and POR15’d it. Have photos. Powder coated Ttop plates and new outer seals installed. Lots of brackets under hood powder coated too.
Needs trunk seal, inner Ttop seals and AC charged.
This is a nice car that draws thumbs up and good comments wherever it goes.
Hit me up with questions.
· Diamond Pistons
More good stuff:
