1987 Grand National
86,000 miles
21,000 on engine
15,000 on tranny
467whp / 489 wtq on street gas
Engine
• Done By Ron’s costume auto
• Block was cryogenically frozen for more strength
• Bore 30 over with forged pistons
• Billet main caps
• 206 cam
• port and polished heads and intake manifold
• roller rockers
• 72mm throttle body
Fuel
• 55lb injectors
• Duel 340 Walboro in tank fuel pumps
Computer
• Upgraded drivers
• 55lb tweak performance chip
Exhaust
• 1 ¾ inch Art aluminum heads
• 3 inch Terry Houston Down pipe
• electric cutout
• 3inch race pipe
• 3inch Duel Pit Bull Exhaust
Turbo
• 720Cfm Precision Turbo
• V2 front mount Intercooler
Transmission
• Worked 700r4 Built By CK Performance
• 9 11 35 stall converter
Suspension
• Atr 1 2/3 sway Bar
• Billstine shocks
• Right side air bag
• Metco lower control arms
• Rear Cross braces
• Energy body bushings
Gauges
• Volt
• Trans temp
• Oil pressure
• Boost
• Knock
• Air/fuel
• Water temp
• Fuel
Other goodies
• Razor Alky kit (never got it to work)
• Translator Plus
• LT1 maf
• Griffin 2 row aluminum radiator
• Be cool 3200 cfm Duel fan setup
• Direct scan
• New M/T dot slicks
• New Rear Weld 15x8 drag light rims
• Greedy boost controller
• Turbonetics Blowzilla blow off valve
• 18 inch K&N air filter
My Camera is broke ill try to get some pics
My name is Steve and my number is (347) 628-9282
Im from Queens N.Y . looking for $12,000 you want it you pick it up
86,000 miles
21,000 on engine
15,000 on tranny
Engine
• Billet main caps
• 206 cam
• roller rockers
Fuel
• 55lb injectors
Computer
• Upgraded drivers
Exhaust
• electric cutout
• 3inch race pipe
Turbo
Transmission
Suspension
• Billstine shocks
• Rear Cross braces
Gauges
• Volt
• Trans temp
• Oil pressure
• Boost
• Knock
• Air/fuel
• Water temp
• Fuel
Other goodies
• Translator Plus
• LT1 maf
• Direct scan
