87 GN with 69000 miles with little to no rust. The interior is in good shape-no rips or tears. Cold A/C and engine temp never goes over 180. Car has new front and rear disc brake pads (87 ford thunder bird rear brakes). The rear is a stock posi. All new front end parts. Car runs and drives great…can take it anywhere. The car made 478 hp with 21 pounds of boost. Most parts have less then 500 miles on them. Car is located in Baltimore MD. $23,000 OBO.
4.1 production block with girdle
JE piston 20 over with hell fire rings
Eagle crank and K1 rods
Roller cam and T&D roller rockers (1.65)
CNC race port iron heads
Stock ported lower intake
Left and Right H&R engine mounts
65 mm throttle body
83 lbs injector
GTQ70 turbo
3500 9/11 converter
Razor alky kit
G-body aluminum
Fast xfi
Poston GNX dash
Lots of other new parts not listed.
Parts I have for the car but not installed are:
-New H&R rear bar
-New LED tail lights
-Stock rims
-5 front and 2 rear GTA wheels
65 mm throttle body
83 lbs injector
GTQ70 turbo
3500 9/11 converter
Razor alky kit
G-body aluminum
Fast xfi
Poston GNX dash
-New H&R rear bar
-Stock rims
