87 GN hardtop
power locks
crank windows
tilt wheel
concert sound
newly freshened engine (5000 miles or less)
hofer built 200 with 3200 vigilante lockup converter
Walbro 340 w/hotwire kit
Accufab Regulator
PT 61 turbo
65# injectors
Cotton Front Mount
Maf Translator 3" LT1
Ramchargers dual fans
RJC Plate
Champion ported lower intake
Accufab 70 mm plenum and tb
TA Stainless 3-bolt headers
Houston Down Pipe w/dump
Hooker cat back exhaust 2 1/2
New Weatherstripping everywhere
Poly body mounts
Poly bushings front suspension
Two inch dropped spindles
1.5 inch lowering rear springs
Gbody parts upper front control arms
HR engine and trans mounts
Centerline Telstars 15x4 front 15x8 rear (powder coated gloss black)
Umi boxed rear control arms
Full Throttle rear sway bar
Big mouth 4" cold air kit
Car has rust in the driver quarter and starting to bubble on trunk lid
A/C is bypassed at the moment (needs compressor and lines to dryer and condensor)
Stock wheels can go with car if desired
$9500
power locks
crank windows
tilt wheel
concert sound
Accufab Regulator
PT 61 turbo
65# injectors
Cotton Front Mount
RJC Plate
Poly body mounts
$9500
