- Aug 11, 2001
All parts are/were in good working order as they came off a 90k mile running 87 GN. These parts must go, no reasonable offer will be turned down!!! Plain and simple, snooze and you loose. I just don’t have the time, so please don’t ask and waste my time if you have no intensions on buying, serious buyers only. Trying to make it as simple as possible. I’ll keep it on hear for approx. 1 - 2 weeks before putting it on eBay. All prices are + shipping.
87 GN 3.8L Turbo V6 (LC2) complete engine with trans, engine harness, sensors, hoses, brackets, relays and accessories. This comes as complete as you can get it with: the a/c (minus lines), p/s w/reservoir, and all the sensors, ECM, MAF, everyyythinggg. Nothing was cut or short cut taken, when pulling this thing out. You wouldn’t need nothing else other than bolts and an exhaust (dp) to put it in place and go. The engine has 90k miles and sounds good. The car was in an accident so obviously it was running. Pan to throttle body including intercooler and plumbing. Although the turbo makes no noise it does have some play (may be original) and may need replacing in the near future. Every thing seems to be stock with no performance parts. The transmission is a BRF 200FR. I sold one just last year (140k miles) for the same $$$ that I’m asking for this 90k mile engine. $2,800.00
87 GN Dash w/Plaque no cluster & trim (latch broken on glove box, easy fix) $300
Shifter assembly with chrome stalk $35
T TOP trim pieces around the t-tops on the inside of the car $20 for each
Rock arms & shafts $55
Fuel rail $35
Lower intake w/new pvc gromet (real nice/bead blasted) $180
Upper intake (real nice/bead blasted) $65
Throttle body (real nice/bead blasted) $100
Valve covers (real nice/bead blasted) $90
Stock pair of heads (8445) $50 a set
Pro Stars 15x8 w/3.5BS with drilled holes $200
8.5 G80 Posi rear end stock drum to drum $750
87 Black Grille (slight crack on bottom/back side, cant notice when instaled). $175
87 Chrome Grille $100
Aftermarket Spoiler (?) 3 piece $120
Rear Tail Light (cracked lens) $45
GN Rear black bumper $75
Reproduction GNX flares: All four flares need fiberglass work. I believe these are the ones Kirban sells (not sure if anyone else made them). Look at pics to determine what they are worth. They come with the gaskets. Included is a left side reproduction GNX side vent. $bo
Heater box complete (minor crack, look at pics) $100
Windshield wiper motor $10
Windshield wiper arms (black) $55 pair
Inner fenders $100 each or $175 for both
Vacuum brake complete set up $85
Front sway bar $20
Braces Kit: for front end with bolts. 3 piece for lower end that form a triangle (pics: the long piece is slightly bent and needs to be straightened out). Also the top 2 pieces that connect to the inner fenders to radiator support (one of these also need straightening). $65 obo
Pwr steering gear box (quick ratio) $40
Pictures by Buicktime - Photobucket
Will trade close or equal value part for: Freshly rebuilt stock turbo, NOS roof rail weather stripping, new to very good shape front and rear bumper fillers.
