87 Hardtop GN. It was restored sometime before I bought it. The paint is deep and slick. It has small chips here or there, but IMO it's an 8/10. All panels are original GN steel except for the glass bumper fillers. It was a low option, no cruise, defrost, manual window car. It has an aluminum core support, one piece front spoiler and new trunk carpet. Vacuum brakes, with all new stainless lines front to back and a wilwood proportioning valve. It has a mild steel 10 point cage with removable swing out door bars, window net 5 point harnesses. It still has all of the original interior that is in excellent condition.
9" rear.= with HD axle tubes, back braced, Moser 35 spline axles, adjustable upper and lower control arm brackets, adjustable spring perches, moser iron center with 3.50 gears and detroit tru-trac posi.
Double adjustable upper and lower control arms and anti-roll bar, Baer SS4 12" brakes with parking brakes. Viking DA shocks
SC&C stage 2 front suspension with SPC uppers and lowers with Howe tall ball joitns, Hotchkiss springs, billet tie rod adjusters and Hellwig sway bar. Baer T4 13" front brakes on new spindles. The has all the factory power steering and new moog links. Viking DA shocks.
The wheels are 18x9 front and 18x11 rear weld RTS's with 245's front and 305 drag radials rear.
It has a new stock replacement tank with a racetronix 640lph double pumper, braided lines, holley filter, flex fuel sensor etc.
$16,800. Drop in your drivetrain and electronics.
