I've found a 71k mile 87 GN with T-Tops that has a considerable amount of rust. The entire T bar is rusty with holes going through where the T-Top bolts in. The pillers are not rusted but when I pull the carpet the drivers side has surface rust and the front passenger floorboard has a hole.
The passenger rear floorboard is completely gone. Drivers side door is ok but the passenger door has a hole from the outside with the bottom length rusty.
The front is near perfect and the rear trunk lid has a hole but the underneath part of the deck isn't too bad. On the roof drivers side on the back side of the T-Top trim there is a small hole where water can barely get in.
The drive drain is completely stock (getting from original owner). Shocks feel bad and steering wheel/column is broken. The owner had no idea of the real shape until I starting removing trim and pulling carpet.
I wanted to buy it but now I'm not sure if I should. Wanted a driver and now feel I could only part it out. What should I do. Is the body really that bad?/ Any ideas?
