sean lawrence
- Jan 13, 2013
You mentioned you ran the ground wire for the tps sensor to the battery. That is a mistake. The tps ground wire has to go back to the computer not the battery. The tps shares it's ground with the coolant sensor and the air temperature sensor. Try unplugging the coolant sensor and the ATS and see if you still have the problem. Maybe I missed it but how are you measuring the voltage and with what? On a side note you don't need 4.6v@WOT. Anything over 4.1 volts is enough.
you need to read the entire post before you chime in. a ground is a ground is a ground period. I am a ase mechanic and im not stupid and I I also have a ba In mechanical and electrical engineering so your not correct. but thanks for the advice.You mentioned you ran the ground wire for the tps sensor to the battery. That is a mistake. The tps ground wire has to go back to the computer not the battery. The tps shares it's ground with the coolant sensor and the air temperature sensor. Try unplugging the coolant sensor and the ATS and see if you still have the problem. Maybe I missed it but how are you measuring the voltage and with what? On a side note you don't need 4.6v@WOT. Anything over 4.1 volts is enough.
