87 Grand National Hard Top
tmsbuic
Changes in life and loss of interest in the hobby has made my decision to sell my car.
87 GN Hardtop- Located in North Alabama
Drive train and Car have around 30,000 miles on rebuild
Painted in 2001
3.8 Liter/231ci
.030 TRW Forge Pistons
ARP Bolts and Studs
Champion Iron Heads
Cometic Head Gaskets
210/215 Roller Cam from Full Throttle (XR2 Kit)
True Roller Timing Chain
Harland Sharp Roller Rockers 1.5 ratio
60lb Injectors
Adj. FPR
RJC Power Plate
LT-1 MAF 3”
Translator
Scanmaster 2.1
Wideband PLX w/gauge
Turbo Tweak Alky Street Chip 93 Octane w/Alky 5.6
Razor Alky Control
TEC-TPS/Throttle Enhancer
Big Mouth Cold Air Intake w/K&N
PT-54
RJC Boost Controller
PTE FMIC
3" THDP w/electric cut out
Walbro 340 w/ Hot-wire kit
Ram chargers Dual Fans
160 T-Stat w/aluminum housing
PTS street/strip Trans. 200R4
Billet 9/11 3200 lockup
Eaton Posi 3.42 Gears w/Moser Axles 30 Spline
Stock Rims Frt. 235/60/15
Widened Factory Rr. Rims 8inch w/275/50/15 MT-ET Streets
Hooker Cat Back Exhaust (Aero Chamber Mufflers)
No Cat. Installed
Stock Headers
Stock Crossover
Ground Stretcher
1 3/8 rear sway bar
UMI upper and lower rear control arms
Driveshaft Loop
Vac. Brake System out of Monte Carlo SS
Rear seat braces
VDO Gages (Oil Pressure, Water Temp. 30lb. Boost, )
A Pillar Dual Pod
Console Dual Pod
New Rear Variable Rate Coil Springs
JAX Upholstery-Front and Rear Seats
Energy Suspension Body Bushings
“Moog” Frt. Steering and Suspension Parts
6 spare Factory Rims
2 sets of extra factory heads
Original Axles, Posi Unit w/gears
2 Die cast still in boxes(GN and GNX)
90% of Original Parts that were removed still available
6.94 ET/100.7 mph 1/8 Mile (w/22 lbs. Boost) Safe Tune
15,000.00 Includes Car and all related parts
No Trades and No Parting Out.
PM me if you have questions and info about another item that I'm selling that's not Buick related.
Here are some photos
Car will not disappoint. I know this car, super nice ride.
I wish you were in California. I've been looking for a GN for months now, and your price and mods are within my specs.
