87 Grand National Radiator
popjohnson
I bought an 87 radiator from an GN and i was told that it had the oil cooler built right in to it, he stated it was the two holes on the right hand side. Is this correct?
gn radiator
Hi,
The trans and engine oil coolers are both in the right,or passenger side, tank of the radiator.
actually the oil radiator part is on the front side facing the headlights you should have 2 holes on the right side on the front and back of the tank for a total of 4 holes and the holes on the opposite side of the engine should have had 2 factory bent lines attached to the radiator.
