87 regal 307 questions
386kustoms
im almost positive i know the answer but just double checking. i found a 87 regal that has the 307 in it. is a 307 the same block as a chevy 305 or 350? not i do not mean the internals, what i am asking is does it bolt up the same? reason im asking is i have a 84 gn that i need parts off of well i found a 87 regal and my father is building a rat rod project and is looking for a sbc. so im trying to see if buying the car for parts if he can use the engine.
The motor mount up the same (motor mounts) the trans has to be a bop (it will bolt up to all blocks).On the bright side sbc cheaper to build.
307 Olds
I believe a Olds 350 or 455 should bolt in with little trouble using th Olds 307 motor mounts
