87 Regal T-Type Pearl White 15k obo
Dick_0550
Hey y'all, I have to put my car up for sale. I am asking $15000 or best offer, please either email me at RShifflett@gmail.com or call my at 571-839-9994 if you have any questions. The car and myself are located in Northern VA
MOTOR: Buick 231 V-6, 206/206 cam, ported polished heads and intake, 70mm throttle body, new coil and wires. Accel DFI Fuel Management System, 50# injectors, Dual Walbro 340 fuel pumps. 160* thermostat, electric fan, three core Be-Cool Aluminum radiator.
TURBO: T-67 4-bolt w/ adjustable wastegate, 15psi to 26psi. 3.5" plumbing throughout, including Terry Houston downpipe, and aftermarket front mount intercooler. 3.5" Exhaust w/ Flowmaster muffler.
TRANS: Turbo 400 w/ 10" 3100 RPM stall torque converter, reverse manual valve body and Trans brake.
BODY/SUSPENSION: Pearl White paint, Fiberglass hood, front clip, front and rear bumper. All new trim and decals, Hotchkis suspension, Koni Fully Adjustable shocks front and rear, 15" Weld Pro-Stars wheels w/ Mickey Thompson Skinnies on front and E/T Streets on the rear. Battery relocated to the trunk, w/ disconnect switch next to license plate.
INTERIOR: 8-point roll cage w/ driver 5-point harness. Seats and Carpet in excellent shape. Digital Dash, Autometer pro-lite silver gauges. Tach, boost, knock, fuel pres, oil pres, and water temp. Hurst Pro shifter w/ line lock, trans brake and switches located in ashtray. Radio and A/C deleted. Dial-A-Boost system installed next to driver seat.
It is street legal.. The only problems that you may have anywhere is that only the driver side has any safety harnesses, and the catalytic converters have been removed. So if you live somewhere where they do a visual check for cats, then you might need to get a dummy set on there or a racing converter from Summit or something like that. Thanks very much for looking at the post.
