87 t-top gn--8,000.00 for all
WINDMILL
I'm tired of fixing it going to sell it all,, the gn and all the parts i have for the gn goes with it... last time out it broke the aluminum center housing and got the driveshaft and broke trans in half,,,, i still have the other blocks and m&a heads and do have the v-covers for them now...also trans cases too. lots of parts here too... i will get some listing of all parts this weekend if i can..
here and older ad
http://www.turbobuick.com/forums/cars-sale/321834-1987-gn-t-top-car.html
OK this is a little hard to follow. Does this car run? Exactly what is good and what is bad? What does it need?
the motor still runs, but has a broke trans and the center housing is broken... if anyone is really interested call 256-601-6604
109 block 20 over motor too
maft-pro
83 inj
68-h turbo
stock heads
heads studs, main studs cometic heads gaskets
champion 1200 intake,precision hat with powerplate, 70 mm t/body
aluminum pullys rjc's
ATR front mount
3-1/2 thdp with atr 3 inch single exhaust
moser 9 inch rear end 33 spline with aluminum center section, 350 gears spool
Metco uppers d/adj bars,,, and metco non lowewr bars,,,ATR big swaybar
6 point chrome moly cage bolt in and removeable side bars.
notch frame for bigger tire( 325x50x15)
torque-thrust wheels front 15x5 rear 15x8 with 4-1/2 b/spacing m/t drag radials275x60 tire
turbo 350 trans with lots of hard parts in it fron ck perf. deep pan
nitrous driveshaft
rear disc brakes
hydroboost brakes
aluminum bumper struts, no beams inside bumpers too. exports up front.
other parts
1 set of 72 lb inj and chip
1- 20 -20 crank,, 1-- 10--10 cranks
1 cat 4340 crank new
72 gtq turbo
76 p trim turbo
gn1 tall v/covers
1 new braided line feed for turbo
2-1/2 chrome up pipe
gas tank for gn (new)
new BGC aftermarket intake and RJC power plate
1 set of M&A aluminum heads with roller rockers looks like reg chevy rockers
1 set of gn1 aluminum heads with roller rockers -harden rocker shaft
1 set of 8445 heads with no egr ports--stage -1 heads
mark jackson stretch intercooler(been boxed up to put ice in it
duel fan setup with wire pig tail for gn--(new)
extra set of front seat(need recovered tho) good back seat
2- block girdles 1 cat-new and rjc-used too
2 new front cover and oil pumps
1 brand new TA perf front cover assembley
i have 4-- 109 blocks think 2 are std and others 30 over.
3 brf trans core, crossmember and 1 driveshaft
lots of bolts and brackets, 2 power sterring pumps, line and all
extra sets of rod and main bearings, couple sets of rings,, some gaskets
LOTS of small stuff not listed too.
forgot to add,,, all gn parts will go with it i have in my shop, i will not keep any.
maft-pro
83 inj
68-h turbo
stock heads
ATR front mount
nitrous driveshaft
rear disc brakes
hydroboost brakes
other parts
72 gtq turbo
76 p trim turbo
gn1 tall v/covers
Windmill, can you PM me a price for 1 of the std. 109 blocks, nitrous driveshaft, 4340 crank, hydroboost and 3 1/2" THDP?
Just wanted to say that I've seen this car and all the parts in person....there is a LOT of stuff, the parts are worth what he's asking and the car is nice...wish I had the coin...if you go look, you'll buy it
Sent from my DROID2
one block, driveshaft ,hydroboost, downpipe, crank i'll take 8,000.00 for them parts and i'llgive you the rest of everything.
gn1 heads are 8,000.00 and i'll throw in all other parts and car....
also anyone interested in a good car with all the parts,, come buy car and take all the parts to reynolds
its still for sale, guy could not find a way to come get it...
oh anyways the first person with the cash gets it. not holding it for anyone... to much bullcrap..
if anyone interested in it, you can come by on the way to reynolds... i'm in sylvania,al 35988
just cant believe no one has bought this for this price, also cant believe some people still try and jew you on down..... you can make a fast car out of these parts here, it done runs faster than most that i've seen at this price.
still for sale,, might trade for muscle car,, chevelle or so.. looking for a 67 el camino....
