Toddmc66
Import punisher.
- Dec 26, 2012
1987 TURBO-T FOR SALE. Located in Brooksville FL. New paint (factory dark blue) car was media blasted NO rust anywhere, fresh bottom end rod bearings & crank bearings. New oil pump, New ARP rod bolts, New, comp cams double roller gears and chain, 55lb injectors, 205/210 cam, factory mount stretch intercooler, New percision turbo 850 cfm's, New Razor alky kit, Red Armstrong double fuel pump in tank plus new gas tank, hot wire kit, adjustable fuel regulator, Red Armstrong computer chip, Heads recently gone through, New adjustable waste gate actuator, 3inch downpipe, New 3 inch exhaust with dump cap and dynoflow mufflers, New rotors, New rear drums, New suspension bushings front and rear, New springs front & rear, New koni shocks, New Beltech drop spindals, factory rear end with upgraded control arms, all body bushing are New, Pmac transmission 200R4 with 2800 stall, all door, trunk, hood rubber is new from GM, New carpet, Pwr windows, cruise, cold A/C, factory tach & boost gauge, factoy security, factory wheels. I still have the factory rebuilt turbo and a extra set of heads that are new and haven't been used. I dont want to sell but I've lost my job and cant keep the car. The body on this car is flawless. Car runs extremely good. You wont find a cleaner car. Please contact if your serious. Todd toddmc66@gmail.com 352-409-2706
