$13,500.00
Here’s a small list of what’s mostly done. The shortblock is basically a stock rebuild (cam, etc.)124,000 on car
PTE-52 TURBO
PRECISION TURBO & ENGINE FRONT MOUNT INTERCOOLER
42.5 LB INJECTORS
TERRY HOUSTON DOWN PIPE
MAX-EFFORT 16 POS. COMPUTOR CHIP
K&N AIR FILTER AND SOLID MAF PIPE
ADJUSTABLE FUEL PRESSURE REGULATOR
SCAN MASTER SCAN TOOL
PTS 9x11 3200 RPM STALL TORQUE CONVERTER
METCO SOLID ALUMINUM LOWER CONTROL ARMS
LAKEWOOD ADJUSTABLE DRAG SHOCKS
AIR-LIFT AIR BAGS
WALBRO 340 FUEL PUMP.
HOOKER 2.5" EXHAUST SYSTEM
MAGNECORE 10MM PLUG WIRES
AUTOMETER BOOST, TEMP AND OIL PRESSURE GUAGES
B&M TRANSMISSION COOLER
DIRECT SCAN SOFTWARE
DIGITAL EGT METER PURCHASED FROM PTE
ARP WHEEL STUDS
alky kit
Here’s a quick rundown of what’s in the transmission.
modified 13 vane pump
Larger boost valve
modified valve body AKA "shift kit"
Billet forward drum
Alto red band Blue clutches
And a few other minor mods like roller bearings
built by lonnie diers and o miles,not yet installed
PTE-52 TURBO
42.5 LB INJECTORS
AIR-LIFT AIR BAGS
ARP WHEEL STUDS
alky kit
Larger boost valve
Billet forward drum
