Well,the economy sucks and has taken its toll on me,I need to sell this car and get something a little more practical....
Im asking $4000 firm for the car...138k miles,clean title clean carfax. When looking through the RPO codes a friend found that the car is originally a limited,but had most of the parts swapped to look like a regular T...
The good:
- TA49 turbo
-42.5 lb injectors
-SMC alky kit
-Turbo Tweak Chip
-HURST Roll control
-Billet Aluminum Fuel pressure regulator
-Stainless Steel braided line with fuel pressure guage
-Upper plenum spacer
-Ceramic coated Turbo shield
-3'' powder coated up pipe
-3'' powder coated maf pipe
-Billet Aluminum oil tube with K&N filter in valve cover
-CK Performance Stage 1 transmission with 10000+/- miles
-PATS 3000 stall lockup converter
-Terry Houston 3'' Stainless Steel downpipe
-Stainless Steel 3'' Dump Tube
-DMH electric cutout
-2 1/2'' Dual exhaust with Flowmaster mufflers
-Comp Cams valve springs
-Aftermarket Cam (not sure what type or brand)
-Adjustable Wastegate
-Blowoff valve
-NEW Energy Suspension swaybar bushings
-Hotchkis lower and upper rear control arms
-Koni adjustable shocks in rear
-ebaich lowering springs in rear
-Header flanges cleaned up and drivers header welded
-K&N cone filter
-Engine tie down
-NEW rear brakes and wheel cylinders
-NEW AC Delco R43TS spark plugs
-2 guage pillar pod
-Autometer Sport Comp Silver A/F Ratio guage
-Autometer Sport Comp Silver Boost guage
-Autometer Sport Comp Silver Mini tach w/ pen shiftlight
-Pioneer CD/MP3 player
-Pioneer Speakers in front and rear
-16' GTA wheels
-NEW alternator only 300 miles
Stock wheels included
I will also include another block,and a brand new set of 20 over pistons.
The BAD:
The interior,the seats are in desperate need of covers,the door panels are a faded...(the dash and console are in good shape)
The driver side rear quarter panel is a different color white
Needs rear bumper fillers..
Has a little rust around the bottom of the doors and the drip rail area...
The car ran 8.0 @ 85 1/8 on 16lbs of boost and NO ALKY on slicks on an easy launch..I now run around 26lbs of boost with the alky ,with zero knock,should go at least a 7.7 Id think.
The good:
- TA49 turbo
-42.5 lb injectors
-SMC alky kit
-Turbo Tweak Chip
-HURST Roll control
-Blowoff valve
-K&N cone filter
-Engine tie down
-2 guage pillar pod
-16' GTA wheels
The BAD:
