- May 28, 2001
As i put in the transmission section, i overheated my trans and messed up some parts. Now we all know when you shortcut and skimp out you end up paying twice. Really i wasnt skimping out, i just chose someone besides the original builder to look at it. He was supposed to take it apart and see what happened, he has built a few before and i knew hiim from the club. he replaced the center support, thrust washer, either the forward or direct drum(cant remember which) and the 2nd gear band. Thats all that was damaged so thats all he did. Didnt remove the vb because i didnt ask him too and some trash got stuck in the 3-4 shift valve. Which after telling him of the issues i had after i reinstalled it, he was the one who informed me of the fixes for that. So after i removed the vb and cleaned out the vb, i put it back together and i worked fine, for 3 miles, then i lost 4th and then 3rd and limped home in 2nd. So i pulled the trans and sent it back to the original builder. If it was just trash in the system i wouldnt be pissed, but every part he put in is junk now. The center support is bad because he didnt remove the burrs and it got destroyed just removing it, the 2nd gear band was toast after about 15 miles and the tolerances for the clutch packs was off. I dont know but i just assume thats why the high gears went out. When i picked it up i was supposed to be picking up a working trans, not a 50/50 chance. He built/fixed it so i would have a working trans since he was the troubleshooter not me. I asked for some money back since i have to buy parts twice. He answered me 3 times and offered me 50 for just the center support and i said 200 then he told me he was done with me, thats its my fault for cutting corners, which i didnt do. I replaced what he suggested i replace. Now he wont answer pm's and he never answered my texts.
