INTHEEIGHTS
My Dads Faster Than Yours
- Apr 15, 2004
LIST OF INTERNAL PARTS LIST .
block 1987 .109 block .030 over.never been dyno yet brand new
billet main caps
block and heads have been o-ringed
arp hardware/head bolts mainstuds
stock crank/rods with arp bolts balanced .
double roller timing chain.
cam atr 309 g full roller
t&D 1.5 ROCKERS
heads, cast iron champion ported, manley valves, comp valve springs.
forged trw pistons with total seal rings balanced
intake upper hemco with 70 mm accufab throttle body
port match lower and jet coated with 83 lbs sem injectors
pte polished charged/ discharged 3 inch tubes
terry houston 3 inch down pipe atr pit bull muffler
stock headers that have been coated they been repaired once
t-72 p tim .082 a/r turbonetics with race gate .
all brackets and pulleys have been jet coated or chrome plated.
TRANS 400
hd sprag
straight cut gears
race clutchs
Trans specialty 3800 stall convert
full race reverse valve body
sfi approved fly wheel.
THIS MOTOR IS READY TO DROP IN YOUR GN AND WITH A FAST STAND ALONE FUEL MANAGEMENT. RUN IN THE NINES. THE MOTOR WAS PROFESSIONAL BUILT BY AGGRESSIVE AUTO. LESS THAN 500 MILES ON IT.
BRAKE IN TIME ONLY. BUYER CAN PULL OIL PAN AND VALVE COVERS AND INSPECT..... I went to a stage 2. Please if your not interested don't waste my time or yours. Located michigan. Over $14,000.00 invested in parts and machining.
$10,500.00 obo. Thanks (269) 605-6548
billet main caps
t&D 1.5 ROCKERS
TRANS 400
hd sprag
straight cut gears
race clutchs
