911 convertor
charlloots
SMO-CUM
is this a 9 in convertor with a 11in clutch i am thinking about getting a 9in cinvertor the car is not a daily driver it has a 11 in now 3000 stall at 6 psi what kind of improvments can i expect going from a 11 to a 9 and should i change the stall speed . what is the 911 convertor i heard about .thanks for any info
I'd keep the same stall unless you think you need to go higher. The 9" bowl makes it lighter and more efficient. I am very happy with my 9X11 and I'm sure you will be too.
it is a 9" converter on crack ..:D
it gives you all the benifit of a 9" converter but yet gives you a lockup clutch to boot.
well worth the money ..;)
