94 Bonneville won't start
wagon
2 doors just aint enough
I've got a 94 Bonneville with the 3800 motor (not supercharged, unfortunately)
I've got fuel pressure, and spark, but the injectors are not firing. It will run if you shoot some starting fluid into it. I've replaced both the crank and cam sensors. It just started stalling, and then sometimes would take some time and a few tries to get it started. Then it wouldn's start at all. When I replaced the cranks sensor, it started right up, but then died about 2 minutes later. Just before it dies, you will usually get the ding alarm, and the check gauges light will come on, but the gauges look fine, and it cuts out. I'm trying to get this thing out of my garage, but need help bad. Does any one have any ideas what it might be? Thanks in advance.
Brian
