Whtlightning
- Oct 13, 2003
I turned on the A/C the other day and my guages went dead, the check engine light came on and I caught the unpleasant scent of burned electrical components. Using a paperclip diagnostic I'm gettin a code 32, EGR. The car has a powerplate and head work and the EGR has always been blocked off, but the check engine light has never came on. I replaced all fuses, including the blown guage fuse, and I disconnected the positive battery terminal, but I can't get rid of the check engine light. My real problem however is my A/C clutch will not engage. I've jumped the connectors on the accumulator and the high presure cutoff switch with the engine on and the setting on MAX cold, but the clutch still won't engage. I noticed I don't have a diode on the compressor clutch connector. Since my diode is MIA, has the ECM been damaged? If you haven't guessed, electronics is not my forte? I spoke with some GN guys, but apparently their wiring is different. For instance they have an ECM/SOL fuse and all I have is a ECM/IGN fuse. Any ideas? It's getting quite warm here in Houston.
