Car died and now won't start.
87gn turbo16
Total rookie here and have a 87 GN and could use some suggestions. Car completely shut off while driving. Won't start now. Things I've done are:
Checked all fuses
Confirmed good FP
Checked for spark and no spark
Checked for injector pulse and no pulse using Noid light
Disconnected battery and reconnected.
Charged battery.
Took off module and coil pack and tested with meter and can't seem to get any readings.
Inspected crank sensor for loose connection looked good
Car has a alky kit
Scan master
TT chip
60 lb injectors
MAF is original
ECM is original
Module and coil
Leaning towards buying new ignition Coil and ignition module but ouch
Loss of the crank sensor signal will kill the engine.
Balancer loose?
Timing reluctor wheel on balancer loose?
Sensor damaged by the reluctor?
All fusible links good?
"Took off module and coil pack and tested with meter and can't seem to get any readings"
How did you do that?.
Check the fusable links by the starter. They are notorious for this problem.
After the above, then check for ignition module connector and possible loose pins or 2 main bolts that hold it tight etc.
You might need to pull the coil pack, flip it over and see if it's melted goo under there.
Balancer loose?
I ran the ohm meter across each coil with 0 reading
