JDSfastGN
- Jun 16, 2001
I recently got my Ac back up and running. It has a new evaporator, self adjusting oriface tube, delco compressor and new accumator. I vacuumed out the system but only for about 15 mins. My numbers on a 95* day are 30-35 low side and 275-310 high side. It's been hot and this is around 1500 rpm. I bought a pressure cycling switch meant for 134 and in the driveway it doesn't cut off until 20 psi and around 4300 rpm. The problem is that it kicks off at no boost below 4000 rpm throttle just for normal acceleration blowing hot air. When it's on, it's cooling well, but it won't stay on. I put about 3.5 cans in with the proper amount of oil. Could this be an issue with not vacuuming out the system long enough? Any suggestions? Thanks.
