Sixstringterror
- Nov 13, 2006
I have an issue with my A/C..When i tryed to recharge my system, on the first can the dial gauge that came with the kit showed that the pressure was way to high..(in the red)...It only stayed in the red when I had the can all the way opened..I tryed turning the can valve down to where it was barely open and it stayed in the green...Then after about half of the first can the compressor kicked on and the gauge dropped down alot...I then turned up the valve to wide open and it was in the green until the compressor kicked off and it shot up to way in the red...After 2 and a half cans the compressor kept coming on and off and the air in the car was getting cold and then the compressor clutch started slowing down and finnaly quite turning...I noticed that the lines were real hot as also the compressor...Dont know where to go from here...Could it be the compressor or is the lines stopped up or what?....Please help and if you need anymore info I'll get it for you.....You guys ROCK!!!!!!!!Tim
