Last night I hooked up my vacuum and pulled the air conditioning system down to right around 28 in/hg. The system held this for at least an hour, at which time I decided to charge the system.
This is a brand new system with exception to the evaporator. I think that is the unit the orifice tube feeds into and the accumulator as well.
So I let the system pull in approximately 2 and a half cans of r134a at 12 ozs per can. Estimating this to be about 2.6 lbs or so. Somewhere behind the compressor, seemed to be where the bulkhead fitting bolted to the compressor I hear a hissing noise.
A couple of questions:
1st That isn't supposed to happen right.
2nd As the system was drawing in the refregerant the low side qauge read as high as 70 psi. I thought it was only supposed to be as high as 35 - 40 psi. Is that correct?
3rd If indeed I do have a problem on the back of the compressor and I resolve this. Will I need to reclaim anything I have put in the system and start over?
4th I started the car and could not get the compressor to engage, brand new compressor. I tried jumping the switch off the accumulator the fans would come on but no clutch engagement.
