a change
tb8125
Hey guys I just picked up a few odds and ends. I bought a scantool walbro 340 fuel pump and hotwire kit and a accu fab fuel pressure reg, fuel injector deka IV 60LB hr long RJC hybrid boost controller Airflow Distribution Power Plate..... plus hooker 2.5 cat back.....
My question is will I see any changes or improvements with just these part add....
I have plans for new turbo ta-49
and a downpipe plus a ALKY kit
new plans to race just want a strong car that will go when i need it to
You might not notice a huge difference power-wise but those are all things that you need so don't feel like you wasted money. The scanner will allow you to monitor for knock. The power plate will let you run higher boost with less chance of leaning out the rear cylinders and the RJC controller will let you turn up the boost. So, the parts alone won't give you more power, but the ability to turn up the boost will. Just don't go too crazy until you get that alky kit.
Cat-back exhaust will help, but get rid of the cat too if you really want to gain some power from your exhaust.
One of the most noticable improvments I saw was an injector change.
This was on a 130,000 mile car so I assume the injectors were very dirty.
I think I would go with mods in the following order:
alky
boxed LCA
large neck IC
large rear sway bar
turbo
down pipe
gnpartsonline has a good deal on DPs on up to 4" with good clearance. The 3 1/2" DP comes with a dump pipe for only $300. gbodyparts has a QTP electric exhaust cutout kit for i think $150. You'll love it.
the hooker catback is nice and stealthy too. meaner than the stocker, but still verrrrry ninja quiet.
when i put my new fuel pump and hotwire kit in, it felt like a new car. the old pump was only getting about 10.5 V.
the biggest single change to my car was the hooker system with testpipe......outside of losing the stock chip.
