85 Riviera
- Aug 19, 2002
On thursday I will be droping my pan to replace the spring in the Line Bias valve with a roll pin, but I have a few questions.
1. will replacing the spring with a solid pin raise the part throttle shifts points?
2. will this firm up or effect all gears in part throttle, 1-2 2-3 3-4?
3. what does the line bias do in relation to the pressure regulator valve because I notice that the modulated TV runs from the Pressure regulater valve to the line bias valve, does it increase line pressure?
4. will doing this cause more holding pressure for the clutches and band and or will this cause firmer full throttle as well?
Sorry for all the questions I just always like to know why I'm doing what I'm doing, Thanks So Much Again For Your Time!!!
