First, some cars respond very well without the need for a progressive. It depends on boost level wanting to be run, type of turbo, converter, etc.. For higher boost(20+ PSI), things change. The bogging can be addressed by upping the turnon point. But too high a point will lead to knock.
The only thing I will say, the current SMC progressive Steve has, is not adjustable on its ramp speed. And limited to 20 PSI due to the internal transducer built into it. This may change, but my understanding is currently, thats how it is.
The issue on the ramp is how much is being sprayed at what boost. To be progressive means as the boost rises so does voltage to the pump. This voltage creates higher pressure.
So for hypothetical, at 3 volts the pump produces 25 PSI. At 10 volts the pump produces 100 PSI. If your not able to adjust how much voltage the box puts out going to the pump, then you cannot tune the car in.
In laymans terms, if your car operates optimally at 15 PSI boost with 50 PSI alcohol.. and the pump used requires 5 volts to generate 50 PSI alcohol, you need your controller to be able and supply 5 volts at 15 PSI boost. If it puts 6volts, too much. 4 volts too little. When it goes to 25 PSI it needs 8.5 volts.. you see where this is going.
You cannot tune individual boost points with my controller, but its accelleration is linear(adj) to the fueling requirements the motor needs. And chip programming can make up a lot of fueling linearity issues.
Lots of guys happy with theyre SMC kits..
I'll leave things at that.
